Baud Rate Variable
- asmith_class1
Baud Rate Variable
It would be a really cool feature if you could adjust the Baud rate programmatically instead of it being hard coded through the connections screen.
Re: Baud Rate Variable
Hello asmith_class1,
You are correct! This is a great idea, in fact, it is in our list of work to be done.
I don't have an estimated time or version of PowerVision Configuration Studio that will include the feature though.
Thank you for your interest in PowerVision Configuration Studio!
- jbilleter
PVCS 2.9.21075
Win 10 Pro
TEC-10, MPC-10, MPC-20
It would be nice to have the CAN port baud rate as something that can be changed in the field. More and more, I am seeing the end users trying to add one of these PowerCore controllers to an on highway engine with a 500 kbps baud rate for the J1939 data. They cannot change it in the field from the default 250 kbps and it ends up wasting a lot of support time and down time.
Thank you
Win 10 Pro
Thank you
Jacob Billeter
Staff Engineer - MurCal, Inc.
It can be done. The CAN speeds are variables. Here's a calculation event to change the speed to 500 kbps. Change the variable to survive power cycle.
Event to change the CAN speed and save the variable. Give it a second before doing a power reset.
- jbilleter
Hi Boyce,
I know that it 'can' be done by creating a custom configuration. I guess I meant to request that it gets added to the Murphy standard releases for the TEC-10, MPC-10, & MPC-20 within the menus so the end user can select it in the field. This way, it would not require a custom configuration to be made after the end user purchased the TEC-10.
Thank you.
Thank you.
Jacob Billeter
Thanks for the suggestion. I forwarded a message to the Product Manager.
