Dynamic X and Y Positions
- chagnonp
I was wondering if it were possible to change the x and/or y positions of image/text widgets through scripting? Thanks
						- jtabb
Re: Dynamic X and Y Positions
chagnonp,
Sorry for the late response. You may already have had an answer.
You can move objects using the screen application in either scripts or state machines. To move an object use:
So the code below would move an widget named IW_1 to position (0,0).
processScreenApi is required to execute screen functions.
screenApiMove(uint screenObjectId, uint xPos, uint yPos)Code: Select all
screenApiMove(screenObjectID(IW_1), 0, 0);
processScreenApi();Thanks,
jtabb
FW Murphy Development Team
