I got an application from customer side who used our PV750 as the display communicated with other controller.
When controller sent a data then the whole screen will be shield(overlay) by a 800*480 size pictures . Under this occasion , they customer want to use the following action to unlock the screen:
Go back to menu -> Screen manager ( can be added unde rUtilities Menu)-> key pressed enter into Screen manager and generated a Dynamic Password (six numbers between 0~9)...
The problem is I don't know how to generate this password....
Your quick respond will be appreciated..
Terry
PV750 screen shield unlock with password
- bseidl
Re: PV750 screen shield unlock with password
Hello Terry
Six variables can be used to hold the six numbers.
You can use an algorithm to generate numbers for the six variables. I do not believe Angel Script has a random number generator.
Let us know if you have any more questions. Thank you!
bseidl
bseidl
