Hello To All,
I got an application that will need 750 to send bool data and analog data by CANOpen to the controller.
My requirements are as follwoing :
1. There 8 eight parameters and 2 states of each need to be adjusted, How to use a Next funciton key to select a special state of a special parameter? After selected, using another button or keybroad to set the value and sent them to controller.
2. when controller received the data which 750 sent, they will broadcast a heartbeat to 750 then 750 will stop send the data or else 750 will send the data all the time.
Doe anyone who \have a demo or some good advice?
I appreciate your help in advance.
Cheers.
Terry
parameters setting
- twang
Re: parameters setting
This request has been turned into a project.
It can be done using state machines with calculation events to adjust the values and Free Form CAN messages to send them over CAN.
