Hi
In script is it possible to read the X & Y co-ordinates of an on screen image widget?
Regards Brian
Reading Graphics X Y
- BrianM
- TStapleton
Re: Reading Graphics X Y
Hi BrianM,
Welcome to our Forums! To better answer your question it would be helpful to know which version of PowerVision you trying to accomplish this with? The version number should be located at the top of the PowerVision window. If you do not see it located there you can go to the upper right hand corner and click on the About button.
Travis
Travis
- BrianM
Hi
Thanks for the reply, the PowerVision I am using is version 2.3.1157 and I am working on an HV700 display.
Regards, Brian
Regards, Brian
- TStapleton
BrianM,
In PowerVision, version 2.3 on an HV700 display, it is not possible to retrieve the X & Y co-ordinates of an on screen image widget via script.
Travis
Travis
- BrianM
Do you know if this be a feature that may be added?
Re Brian
Re Brian
- TStapleton
BrianM,
This feature is not currently on the plan to be added, that does not mean that at some point in the future it will not be added.
In doing some research for this response I was informed of a work around to your issue. What you could do in your script is to keep track of where the on screen image widget starts(X/Y coords) and track where/how you move it in your script. This is not an optimal solution, but the only way that I am aware of for you to accomplish this.
Travis
Travis
