I have run into to continuity issue between the displayed text in the configurator and on the PV750. I have text that is 20 in height and 30x50 dimentions and center / center. The text is "16V". In the configuratior, it displays on 1 single line and fits into the image widges box behind it. When loaded into the PV750, it places it in 2 lines, with only the "16" showing, but located high, out of by graphic. The "V" is hidden.
To fix it, I increased my text envelope size and moved the text over to comensate.
This was a very frustrating one, as everything appears correct on the configurator display, but not on the PV750.
BUG: Configurator to PV750 continuity issue
- mbowdich
Re: BUG: Configurator to PV750 continuity issue
I can certainly understand the frustration. The display you see in the configuration tool is a very close approximation but as you see there are still some discrepancies that can occur. Currently there are multiple rendering systems to synchronized running on three platforms. We make every effort to ensure what you see on the display matches whats in the configuration tool. However because of the difference in platforms its possible for the size of a specific font to return very slight differences in size based on the OS/Rendering engine.
This is a problem we are definitely working on during each release so please send us examples of the discrepancies you see and we can use them as test code for our testing and improvements in future releases.
