Retrieving values from a file
mbowdich
Post by mbowdich » Tue Jul 12, 2011 9:17 pm
I need to retrieve values from a file and pass them on to variables in the database. It looks like they have to be type Double to be passed in. I have tried, but I have only been able to manipulate string in or out of files.
I would prefer to read the data in as binary, rather than having the data stored as numeric text. I tried using several of the functions [readUInt(length), readInt(length), readDouble(), readFloat()] from http://www.angelcode.com/angelscript/sd ... _file.html , but I cannot get any to work.
I have a very strong need to be able to store and retrieve binary date from a file.
dwills
Re: Retrieving values from a file
Post by dwills » Thu Aug 18, 2011 4:17 pm
The version of AngelScript that we support is older than the version documneted on the website, so not all of the functions are supported at this time.
mbowdich
Post by mbowdich » Fri Aug 19, 2011 6:36 am
I have found a work around.
However, when support for something is referencing a website, then you should make sure that the website referenced is the correct version, or obtain a copy of the correct version documentation and reference that.
