I tried to enter a J1939 variable that contains 5 ascii digits.
I noticed that a Byte Length of more than 4 is not possible.
I see in the J1939-71 standard that a variant exists 'SAEat0005' that would allow this.
Are you deviating on this point from the standard ?
Perhaps it would be handy not to limit the amount of bytes to 4 but limit them only to the remining number of bytes in a parametergroup when editing the parameters ?
J1939-71 slots ascii
- young123
Re: J1939-71 slots ascii
You should be able to accomplish this by using a try using a FreeFormCAN message. This tool can handle a number of scenarios that we don't currently support in the standard PGN Setup including handling larger than 4 bytes...(up to all 7 bytes).
- Josh.b@ST
7 bytes if you count from 0, 8 if from 1.
Just to clarify.
Just to clarify.
