cconner_aie
Post
by cconner_aie » Thu May 05, 2016 2:47 pm
We just got done troubleshooting a new application and we found a rather annoying problem.
If I have to send the ETC5 Neutral Switch only on PGN 65219, I tell the PV480 to send the following:
PGN 65219
Priority: 3
Source: 228
.png)
Default Value = 1
This then sends the can message:
CAN-ID: 18FEC3E4
CAN-DATA: 0xFFFD
The Denso ECU we are using will then stall and refuse to respond due to a malformed can frame error - no DTC's.
In order to correct this behavior we have to pad the rest of the message with F's by doing this.
.png)
Default Value = 1
Is there a hidden function in power vision that I'm unaware of to set a bit length and pad without having to add this extra field on every message we transmit?
Coleby Conner
Post
by stalley » Fri May 06, 2016 7:54 am
Hello cconner_aie,
It looks to me that you found the quickest way to fix it, just add byte 8 to the parameters. It looks to me that the default is transmit to xFF, so you don't have to do any special initialization.
Sorry nothing up my sleeve...
cconner_aie
Post
by cconner_aie » Fri May 06, 2016 8:18 am
Just wanted to confirm that before I go through and start doing this for all our messaging.
Coleby Conner
