How could we change a text on a text widget with a received J1939 message's status field which is defined in the database?
Example: For Torque/Speed Control 1 message's Override Control Mode field;
if received message's first byte's first two bits (Override Control Mode) value is "0", text widget's text needed to be "Override disabled";
if received message's first byte's first two bits (Override Control Mode) value is "1", text widget's text needed to be "Speed control"; ...
I gave the example for preventing a possible misunderstanding, general explanation about the situation could work also. Thanks for your help.
Muhit
Changing text widget's text with a received J1939 Messages?
- muhit
Re: Changing text widget's text with a received J1939 Messag
Hi Muhit,
There are several ways to do what you want, an easy way is to use a Smart Text Widget.
When you EditSmartLabels... the Selector Variable will be the J1939 variable.
You will add Selector Value: 0 with the DisplayValue set to what you want.
Same for a Selector Value 1
- muhit
Hi again,
I forgot to mention that I'm using PowerVision Configuration Studio 2.3 for PV750. I didn't find a Smart Text Widget component. Could you be more specific?
Thanks for your help and time.
Muhit.
Muhit.
That's ok. You just have to go through a few more steps to achieve the same thing.
You will want to use Multilanguage Text Widgets, one for each of the different text you want to display.
On each of the new text widgets, go to the properties on the right side, set the Visible Condition/Condition Enabled to True.
This exposes the rest of the properties you need to set.
Condition Variable is the J1939 parameter
Minimum and Maximum Values will need to match up to the Data/text that you need
Include Max Value should be true, in this case
For some examples, you can use the configurations found when you select to open a configuration in PowerVision configuration studio. There should be a list of configurations on the top left, they have lots of examples of how different widgets are used, programming, setting up the input and J1939 ports. You can open, copy and these for your use.
- muhit
Thank you, it really helped.
