Digital Output Condition
- Rivlin
Hello
We are trying to use a button to drive the engine on PV750. There is a fire event for key down that should operate a digital output (for the starter 24V). Key up should stop the digital output (0 volt). We would like to use a condition for the output: if The engine is not driven so we want to enable the ingnition (output). The state of the condition is given through canbus. Variable "J1939.Engine.Engine Speed".
Unfortunately, the output does not change according to the engine state: our syntax in the state machine for condition to transition is “IF("J1939.Engine.Engine Speed" = 0)”
We look forward for help.
John.
John.
Re: Digital Output Condition
Hello John,
If that is an event condition or a calculation event condition the if() is not necessary, the comparison alone will return true or false ( 1 or 0 ).
If you do want to use the if() function it works like in Excel, where the first expression is the evaluation, the second expression is the result if true, and the third expression is the result is false.
"J1939.Engine.Engine Speed" = 0Code: Select all
if( "J1939.Engine.Engine Speed" = 0, 1, 0 )ksaenz
- Rivlin
Hello
I understand that the syntax was good, so I am asking again and attach the file of our configuration:
I am trying to use a button to drive the engine with PV750. There is a fire event for key down that should operate a digital output (for the starter 24V). Key up should stop the digital output (0 volt to starter). We would like to use a condition for the output: if The engine is not driven so we want to enable the ingnition (output). The state of the condition is given through canbus. Variable "J1939.Engine.Engine Speed".
Unfortunately, the output does not change according to the engine state: our syntax in the state machine for the condition to transition is “IF("J1939.Engine.Engine Speed" = 0)”
Key up always work no matter what is the condition of "J1939.Engine.Engine Speed".
I attached my configuration.
Programming item is "Start-Stop EngineControl" and the state machine is "Start Ignition"
John.
John.
If you tried to attach a file with a .murphyConfig extension the board's system rejected it. There were problems with incomplete downloads before so now we recommed attaching .zip files which are easier to check for completeness.
Seems that the problem wasn't the expression but the event that is happening every time even if the condition is false.
On key down are you firing the event or the event condition?
If you fire the event directly the condition will be ignored and the transition will be triggered.
If you fire the event condition the experssion will be evaluated and if it is true the transition will be triggered.
I attached an example of what shows this.
- Event condition on key down - 2320006.zip
- Created with PVCS 2.3.20006
- (605.64 KiB) Downloaded 30 times
- Rivlin
Thank you very much for your help!!
Now it's work fine.
Jon
Now it's work fine.
Jon
- Rivlin
Re: Digital Output
Hello ksaenz
Please I have another question:
When we operate digital output, is it possible to short to ground (instaed of having 24V?)
Jon
Jon
- Rivlin
Hello ksaenz
Please can I have an example for using a timer?
Thanks in advance
Jon
Thanks in advance
Jon
Here is an example for using a timer.
The new variable and state machine can be found in the "Timer" folder.
Pressing key 1 causes a transition from initial state to wait state.
On entering wait state the new timer is started.
When the timer expires it triggers the transition back to initial state.
On exiting wait state the new variable is incremented.
- Timer example.zip
- (115.07 KiB) Downloaded 28 times
- Rivlin
Hello ksaenz
When I tried to download the example, I got the message “ Selected configuration version is newer than the application version”. What should I do?
Jon
Jon
- Josh.b@ST
Rivlin,
From personal experiance, i would say you need to update your PVCS tool.
Might be worth waiting for a Murphy employee to confirm though.
Josh
Josh
- Rivlin
Thanks...
I will ask a Murphy employee
Rivlin
Rivlin
Hi Rivlin,
That message does mean that you need a newer version of PowerVision Configuration Studio to open the configuration.
The posted example configuration was created using PVCS 2.3.20006 which is the latest released version.
You can download PVCS 2.3.20006 here:
viewtopic.php?f=3&t=759
It is important to upgrade to 2.3.2xxxx and you learn more about it here:
viewtopic.php?f=3&t=757
- ergun
When we operate digital output, is it possible to short to ground (instaed of having 24V?)! İ can see that the variable İO.DigitalOut is changing the state(0/1) but nothing happens on the hardware output. İt doesn't matter if İ connect to ground or to power supply using a pullup. What am İ doing wrong?
BR
Serdar
BR
Serdar
