PowerVision Configuration Studio 2.9 Patch 1 is a color display only release. Watch for the upcoming release of PowerVision Configuration Studio 2.9 for monochrome displays! Please read the Usability and Feature Changes in PowerVision 2.9 before upgrading a configuration built with previous versions of PowerVision Configuration Studio. There is a link to the document at the bottom of this post.
This release has some major changes along with performance enhancements and bug fixes so it is considered to be a Beta version due to the new changes in this release.
Major 2.9 Patch 1 Changes are ...
- AngelScript compiler is upgraded to 2.31.2 providing lots of new and improved capabilities. For more details, see the Scripting Syntax Reference tab while editing a script in PowerVision or check out the AngleScript website at http://www.angelcode.com/angelscript.
- Scripts compile in PowerVision on the computer, no display is required to compile and check out your syntax errors.
- Performance Enhancements resulting in amazing speed for deleting and finding items in even the largest configs.
- M2 Only - Differential installs. After a full install of the patch 1 version of firmware on your display, you will be able to use the load diff buttons when you create a configuration and/or full install. This will load only files that are different from the files already on the display. Makes updating configuration or application firmware faster in many cases!
- M2 - An expression may be used for a Visible Condition.
- Reliability improvements to the TCP conduit.
The Usability and Feature Changes in PowerVision 2.9 document provides more details. Download PowerVision Configuration Studio 2.9.20040
Download PowerVision Configuration Toolkit 2.9.20040
PowerVision Configuration Studio reference manuals are here.
