I am new to the powervision configuration software.  I have some experience programming plc, arduino, and a few other microcontrollers.
I have a few questions about how to do certain tasks.
I am using the mpc 20 controller and building off the default configuration.
I am wanting to use Relay 6 in the following way.
I want it to pulse on and off whenever the "LowFuelLevelWarning" becomes active.
if LowFuelLevelWarning =1
Relay 6 "on"
delay 2000ms
Relay 6 "off"
repeat
I have tried programming it a few ways using state machines and an activity program.  Can't seem to get it to work.
I know it is an issue with me being completely unfamiliar with the interface and navigating the software.  Any help would be appreciated.
Does relay 6 need to be enabled somewhere up stream for this to work?  I would assume so, but don't know enough about navigation.
Sorry for the dumb question.
Adam
						Pulsing Relay Based on LowFuelLevelWarning
- Adam
Re: Pulsing Relay Based on LowFuelLevelWarning
Here is a document that explains the steps to do to pulse a relay like you asked.
