I'm a newbie.
This event is called from a PV450 Key Press 1 down event.
void $MyNameIsSmiley$()
string sTextTesting = "Hello world";
setTextWidgetText(ScreenObjectIDs.txtSampleChange,sTextTesting);
txtSampleChange is a TextWidget MultiLanguage.
The event was created for this script.
It compiles fine.
It never displays on screen, when I press the button.
Thx in advance.
Isa
Trouble displaying text in a TextWidget
- IsaPaine
Re: Trouble displaying text in a TextWidget
Hello Isa,
After calling the setTextWidgetText() function also call processScreenApi().
Make your text widget a "dynamic" object.
If you are using version 2.3 of the PowerVision Configuration Studio the preferred method to change text on the screen is cultureSetString().
I attached a configuration I made to test the function. The script and events are in the group "Strings"
Let me know if you have more questions.
- Strings.zip
- Created with PVCS 2.3.11147
- (115.02 KiB) Downloaded 28 times
