How do I change the colour of a text widget?
- jpurdum
To be able to change the colour of text in widgets would you just use different widgets and use programming to display or hide the appropriate ones?
- jpurdum
Re: How do I change the colour of a text widget?
You cannot dynamically change the color of text unfortunately. To do what you’re saying though, I would just use a lamp gauge with the same text as different lamp gauge elements but each element would use a different color. Then by simply changing a value in the database variable to which you've attached the lamp gauge, you can change the color of the text.
