How Can I Save and Change a String
- ergun
I want to save and change a string. I will entry a string from keyboard and i want to save that string to eeprom. Also i want to change last saved string how can i do this could me help please .
Re: How Can I Save and Change a String
Hi Ergun,
Thank you for your question! The answer requires some scripting to accomplish what you want to do. This is a very simple example, I'm sure you will have something with more logic, but hopefully this will give you an idea of what you will need to do.
First I created a String Variable, NameString.
On start up, I have the following code executing:
When I want to save the NameString variable:
When you edit a script, there are tabs for Function Reference and Scripting Syntax Reference. These are helpful and provide more information about the valid parameters to the functions and what functions are available!
void $InitializeString$ ()
file f;
string str = "";
int fStatus;
int fSize = 0;
if (f.open( "stringToSave.txt", "r" ) >= 0 )
fSize = f.getSize();
if (fSize > 0)
fStatus = f.readString(fSize, str);
f.close();
smWrite(VariableIDs.fileStatus, fStatus);
if (str != "")
cultureSetString(StringIDs.NameString, str, true);
file f;
string str;
if (f.open( "stringToSave.txt", "w" ) >= 0 )
cultureGetString(StringIDs.NameString, str, 0);
f.writeString(str);
f.close();
- bburgess
Saving keybord generated STRING: Do you have a simplified means to save to PV450' 780 NV memory?
The example above shows the current easiest way to save and restore a string from the flash (NV). We will add support for using actions to save strings in a future versions.
