1.) Configuration Studio 2.7.10459
2.) Display - PV350
I am trying to set an ellipse widget to an oval. If I change the width or height to unequal values (i.e. oval), a circle is maintained using the smallest of either the width or height value as the diameter. If I add a background/foreground ellipse primitive, I am able to modify the X/Yradius values of the primitive to display an oval. 00-02-0926-PowerVision Configuration Studio Page Designer RF v2.7_HR documentation implies that an oval is a valid display type of the ellipse widget. Is this a bug or undocumented ellipse widget functionality?
Dan
Ellipse Widget on PV350
- dmsellers
- dberezowski
Re: Ellipse Widget on PV350
Was curious so did some experimentation. If you select a display type of PV450 and then Advanced, there is a "Is Circle" option which will force an ellipse to be a circle if set to True. I do not see this option anywhere when the display type is PV350 or PV380. Perhaps you found a bug. ;(
