free form msgs and negative values
- asadilan
Hi All,
thanks for the help so far.
free form msgs, how is that sent by the device? is that in the blanket of PDO messages or SDO?
if i linked a variable with free form messages, when the variable is negative, how do i send this negative value?
usually, the MSB is the indicator if it is a positive or negative values. How can i do this? as of now, when the variable is positive, it sends with the correct value, when it is negative, it is stuck sending 0.
TIA
Asadilan
TIA
Asadilan
- asadilan
Re: free form msgs and negative values
can the device interpret data coming in as signed variable?
- vtaylor
As I understand it, PDO or SDO messages in CANOpen are determined by the upper 4 bits of the CAN ID so the device can send either one depending on what you set the Frame ID to.
If you need to send negative values using the MSb as a sign bit, you could script it - if the value is negative, take the absolute value then bitwise or (|) with a bitmask that sets the MSb. (You could also do it with a state machine but it would be fairly complicated)
Another way to represent negative is by taking the 2's complement (this is the generally accepted way to represent negative integers). I really depends on what the device on the other end of the bus is expecting and/or what you're expecting to receive from it.
The way J1939 handles negative values is by defining an offset value in the SPN definition (e.g. temperatures are typically interpreted to be offset by -40°C so a received value of 30 would indicate -10°C).
int8 localValue; //for 8 bit value
smRead(VariableIDs.databaseValue, localValue);
if (localValue < 0)
//take the 2's complement
localValue = (~localValue) + 1; //you could also use abs(localValue)
//bitmask
localValue |= 0x80; //for 8 bit value
smWrite(VariableIDs.databaseValue, localValue);The way J1939 handles negative values is by defining an offset value in the SPN definition (e.g. temperatures are typically interpreted to be offset by -40°C so a received value of 30 would indicate -10°C).
- asadilan
Hi Vtaylor,
Thanks for replying.
I ll definietely look at the scripting side of PV450.
Asadilan
Asadilan
- vtaylor
I don't think it can do that implicitly, but again if you know the data format you're expecting (bit length and how negative numbers are represented) you can use some manipulation in a script to turn it into whatever representation you need. The smRead and smWrite functions have some pretty slick type conversion abilities that can make it pretty easy if you use 2's complement format for negatives.asadilan wrote:can the device interpret data coming in as signed variable?
- asadilan
Hi VTaylor,
would it be something like this?
void $ConvertSignedToUnsigned32$ ()
uint localValue =0;
int value =0;
smRead(VariableIDs.CurrentPortManual,localValue);
smRead(VariableIDs.CurrentPortManual,value);
smWrite(VariableIDs.temp,int(VariableIDs.CurrentPortManual));
smWrite(VariableIDs.temp2,value);
processScreenApi();
where am i wrong here?
uint localValue =0;
int value =0;
processScreenApi();
Here is what I use:
double utos( double x )
uint16 u;
int16 s;
u = x;
s = u & 0xFFFF;
x = s;
return x;
double stou( double x )
uint16 u;
int16 s;
s = x;
u = s & 0xFFFF;
x = u;
return x;
- asadilan
free form msg for Standard Frame Send allows me to send packet with id between 0 - 0x7FF.vtaylor wrote:As I understand it, PDO or SDO messages in CANOpen are determined by the upper 4 bits of the CAN ID so the device can send either one depending on what you set the Frame ID to.
according to CANopen specs, PDO is packet with id above 0x1400, hence my question.
i don't have a protocol analyser that would tell me how this free form msgs sent in the data from pv450.
if anyone can tell me, that will be great.
Thanks in advance,
Asadilan
- mbowdich
It is not possible to have a CANOpen Id above 0x7FF. CANOpen is implemented using 11 bit identifiers, which means the upper limit is 0x7FF (all 11 bits are 1s). If you look at the specification more carefully, you will see that it states that the PDO Index is >0x1800 for producers and >0x1400 for consumers. The index is not the CANId.
