What are the IO definitions when trying to map a analog input to a digital input?
I am trying to change Analog Input 1 into a Digital input but when i select a variable i'm not able to add any definitions
What are IO Definitions on PV380?
- keithbaxter
Re: What are IO Definitions on PV380?
Hello keithbaxter,
You must be accustomed to being coddled by using a color display previously or something. With a monochrome display, you will need to do the calculations yourself.
This is a link to another forum post about this topic viewtopic.php?f=7&t=1041&p=2763&hilit=analog#p2763 There is even an example.
Please come back if you have questions.
