Dear Sir,
Regarding PV450, "Screen Setup" function is removed from PowerVision 2.7. This function was available on PowerVision 2.6.
Please kindly advise how the "Screen Setup" is added in a configuration based on the 2.7.
Thank you and best regards,
Shiii
Screen Setup
- tshiii
Screen Setup
- DSC_0155.JPG (912.67 KiB) Viewed 76 times
Re: Screen Setup
Hello tshii,
If you search in your 2.6 configuration for "GaugeScreen" you will see events, scripts and variables used to control the pages viewed. Be prepared to spend some time studying how the screen setup works and then how you can implement in your 2.7 configuration.
There isn't a way to export variables, events and programming from a 2.6 config to a 2.7 config so this is your opportunity to do the same feature and perhaps improve it!
I would start looking at the variables on the User Settings page for the Screen Setup, GaugeScreen.Sequence, GaugeScreen.OnOff and GaugeScreen.CurrentHome. Search for these variables and see how they are used.
This is a time when it would be nice if this feature were a module that config developers could add or remove.
Please let me know if you have more questions.
- tshiii
Re: Screen Setup
Hello stalley,
Thank you for your prompt attention and the information.
Shiii
Shiii
