I am using the internal DM1 function for fault code handling however the occurence counter does not seem to work. When an fault is set then it stays at count 1.
Also when:
=> not acknowledged,
=> fault code inactive
=> fault code active again
I am using a PV480 PVCS 2.6.20023, FW 2.3.20008
Thanks!
Internal DM1 occurence counter?
- Hfluiter
- pcebuhar
Re: Internal DM1 occurence counter?
Most of the Murphy Standard configuration for PV480, PV450, and PV780 support the DM1 display overlays, but they do not have the Occurance Counter in the display. The Occurance Counter was added and connected to the DM1.OccuranceCount. I sent individual DM1 messages over and over, but the count remained at zero. We believe this is a bug and we will fix it soon.
One reason why there may not be a lot of credence connected with the Occurance Count is that some ECUs will send these DM1 messages out periodically until the situation is rectified.
Phil Cebuhar
Phil Cebuhar
