MPC20 Machine Hours
- dblye
MPC20 Machine Hours
I need the part number for the ECOM Dongle for program uploading to the MPC20. I need to change the engine hours on a customers ML2000 in a mechanical engine application. I guess the panel wants to retrieve engine hours from an ECU, so to access that area of the MPC20, Powervision must communicate with the panel via J1939. I have had great success sending full configs via email that customers upload with the USB adaptor, but it appears that a change in engine hours requires a direct connection to a laptop running Powervision. Is this correct?
Re: MPC20 Machine Hours
Hi!
I just spoke with Adam. It sounds as though you have the part number for the ECOM dongle. Adam knows all of the important part numbers.
You will also need the the PowerVision Field Programmer. You can find the latest installer for it here.
I don't think there is a way to change Machine Hours on an MPC-20 other than with the Field Programmer. The Field Programmer GUI is pretty straight forward, but I will be glad to answer questions if you run into trouble.
It is good to hear that you have had success with your customers using the USB adaptor.
