We've been working on PV780 and we would like to change the first page on PowerVision Configuration Studio 2.7(after the bootup sequence). For example, First Transmission Page View instead of Engine Page View.
We've checked the state machines on the Programming section of the PowerVision Configuration Studio 2.7 but there seems nothing about the default opening page.
The only way we found was to delete the first page, then add a new page and design it from scratch. We think that it should not be the ordinary way of setting this. Could you please show us the way about setting the first page from available page views after the bootup sequence?
Thanks.
How to change the first page after bootup sequence?
- muhit
Re: How to change the first page after bootup sequence?
Hello Muhit,
In the Page Designer, go to the page view you want to be the new startup view. At the lower left of the display outline (the light blue section with the button representation), there is a tab showing the name of the view, Default Transmission View, for example. Right click on the name and you should get a dropdown where one of the selections is Select as Startup View.
The rectangle icon on the left should become a tannish color.
- Esb1983
Hi
My setup is for a PV450 and I have several pages, but can not get it to reboot always start page created for the start, always turned on the last page displayed.
I tried to do as describe above but do not get the desired result.
Regards
Regards
- MuratE
As you know PV780 opens with boot up sequence after power off and on. At first black screen comes with Booting... word after that blue screen comes and at last start up page (if it exist) or main application page comes respectively.
I wonder if it is possible to change boot up sequence 's blue screen and Booting... word. Are boot up pages configurable? Or is it possible to show only black screen during bootup?
I know bootup sequence depends on PV780 's operating system (QNX). But I want to push my luck about configuration options.
Thanks in advance.
Murat
Thanks in advance.
Murat
Eppur Si Muove
Hello Murat,
Look on the Configuration tab, on the ribbon with Configuration Logos. If you have any images there, you can take those out to see a black panel, if you wish. The Booting... text is in the bootloader and not configurable.
- MuratE
Hello Sara,
Thanks for explanation.
Have a nice week.
Murat
Have a nice week.
Murat
Eppur Si Muove
