Hello all colleagues,
There is a customer he want to add only engine diagnostic trouble codes into blank configuration by a packet programe , how to make this programe? Are there any examples? How to cummunicate between ECM and DTCS?
Peter
PV750 DTCs
- pfu
Re: PV750 DTCs
Hello pfu,
The Murphy Standard configuration already does this so you can start with that and clean the pages.
You can also use the PV450 configuration from this post:
viewtopic.php?f=7&t=443
That configuration only has DM1 popups for DTCs so you can convert it to a PV750 configuration and adjust the graphics and the buttons, or you can just use it to understand how the DM1 app works and you can start your own PV750 configuration.
