Question on Programming Transitions
drphil69
Post by drphil69 » Fri May 13, 2011 2:19 pm
I have what I hope is a simple question on the operation of the transitions in programming.
For a transition to occur due to an "event condition," is it correct that the current condition must be the state where the transition begins? i.e. if I have a state machine with 3 states, A, B, and C. Current state is A. There is a transition from state B to state C that is triggered by an "event condition." If machine is in state A, and condition goes True, will the transition occur? I believe that since machine is not in state B, transition will not occur... (actually I hope this is correct!)
Thanks!
drphil69
Re: Question on Programming Transitions
Post by drphil69 » Mon May 16, 2011 3:13 pm
As an added related question -
Are multiple Transition Event Conditions logically connected by OR? i.e. if any of the conditions go true the transition happens?
Thanks!
priyauplaonkar
Post by priyauplaonkar » Mon May 16, 2011 4:55 pm
Hi Phil,
1st question: Yes, you are right. If a machine is in state A(Current state) and the condition goes true, the transition between state B and C doesn't occur. That is because the condition cannot jump from State A to State B.
2nd question: Yes, the multiple transition Event Conditions are logically connected by OR when you are using them with a single state.
I hope this helps.
Priya.
