The graphing widget allows setting min/max limits on the y-axis.
Do you guys think you could allow setting min/max limits on the x-axis as well? Right now you can set the number of data points. If the plot data array has more points than the plot limits (e.g. plot array has 1000 data points) -- it would be great for my application to display portions of the data.
Just for more info -- I would like to "store" 7 days of data but only display 1 day of data at a time (i.e. Day 1, Day 2, ..., Day 7) per the User selection
Hope this makes sense.
Ron Roth
EControls, LLC
Graphing Widget request
- ronaldbroth
Re: Graphing Widget request
Would it work if you defined 7 columns in the list for the 7 days data? You could define 7 graph widgets that are stacked and control the visibility for the widgets.
