Graph Widgets
cconner_aie
Graph Widgets
Post by cconner_aie » Fri May 19, 2017 3:16 pm
I have a question on the graph widgth, it seems like the graph is shifted right (new data added to the left) as new data comes in:
(looking at the blue data).
Is there a way to make the 0 position on the X axis fixed so the new data is added to the right of the the current data rather than vice-versa? Sort of like this (excuse my paint skills).
I found the mirroring option, but that just starts the graph on the right side. Not what I want.
Is this possible?
Coleby Conner
cconner_aie
Re: Graph Widgets
Post by cconner_aie » Fri May 19, 2017 3:22 pm
Here is how I add the data to the list:
int mColdStartRow = 0;
double mColdStartRPM = 0.0;
double mColdStartAmbient = 0.0;
double mColdStartVoltage = 0.0;
double mColdStartCoolant = 0.0;
void $E_ColdStart_Power$ ()
	uint isLogging = VariableEnumerations.V_ColdStart_IsLogging_OFF;
	smRead(VariableIDs.V_ColdStart_IsLogging, isLogging);
	if (isLogging == VariableEnumerations.V_ColdStart_IsLogging_ON) {
		ColdStart_stopLoop();
	} else {
		ColdStart_clearList();
		ColdStart_getData();
		ColdStart_addItem(0);
		ColdStart_startLoop();
	E_Engine_Power();
// every 250ms via timer ET_ColdStart_Loop
void $E_ColdStart_Loop$ ()
	if (isLogging == VariableEnumerations.V_ColdStart_IsLogging_OFF || mColdStartRow >= 480) {
	} else {
		ColdStart_addItem(++mColdStartRow);
void ColdStart_getData() {
	smRead(VariableIDs.V_J1939_IC1_EngineIntakeManifold1Temperature, mColdStartAmbient);
	smRead(VariableIDs.V_J1939_EEC1_EngineSpeed, mColdStartRPM);
	smRead(VariableIDs.V_J1939_VEP1_BatteryPotential, mColdStartVoltage);
	smRead(VariableIDs.V_J1939_ET1_EngineCoolantTemperature, mColdStartCoolant);
void ColdStart_addItem(int row)
	mColdStartRow = row;
	CustomListData data;
	data.WriteInt32(CustomListColumn.L_ColdStart_RowId, mColdStartRow);
	data.WriteDouble(CustomListColumn.L_ColdStart_Ambient, mColdStartAmbient);
	data.WriteDouble(CustomListColumn.L_ColdStart_RPM, mColdStartRPM);
	data.WriteDouble(CustomListColumn.L_ColdStart_Voltage, mColdStartVoltage);
	data.WriteDouble(CustomListColumn.L_ColdStart_Coolant, mColdStartCoolant);
        ListManagerAddItem(ListDataType.L_ColdStart, data);
	//ListManagerSetPosition(ListDataType.L_ColdStart, ListManagerGetCount(ListDataType.L_ColdStart) - 1);
void ColdStart_stopLoop() {
	SendAction(ApplicationIDs.CCM,
		ActionIDs.CCM_Cancel_Timer, TimerIDs.ET_ColdStart_Loop);
	smWrite(VariableIDs.V_ColdStart_IsLogging,
		VariableEnumerations.V_ColdStart_IsLogging_OFF);
void ColdStart_clearList() {
	int last = ListManagerGetCount(ListDataType.L_ColdStart) - 1;
	for (int i = last; i >= 0; i--) {
		ListManagerRemoveItem(ListDataType.L_ColdStart, i);
	ListManagerSetPosition(ListDataType.L_ColdStart, 0);
Coleby Conner
Re: Graph Widgets
Post by boyce » Mon May 22, 2017 4:48 pm
I finally got it to add to the right. Try this after the new item is added:
	ListManagerMoveTo(ListDataType.L_ColdStart, 0);
