Hi, does anyone have an example configuration which uses analog or digital inputs on the 780 screen?
I am trying to trigger an output from one screen based on an engine coolant temperature set point and connect into another screen as an input to drive a binary output to trigger an alarm on that network.
I have used all the network connections and cannot combine them in this way.
Many thanks,
Rich
HVS780 Digital and analog inputs
- Griffon
Re: HVS780 Digital and analog inputs
Hello Griffon,
I'm not sure if I understand the problem. I have probably oversimplified what you described, but maybe this will give you a place to start and some ideas about how to accomplish what you need.
There are two screens. The main screen shows an analog input (0-5). When the input gets to a certain point (100), the digital output is turned on and the second screen is shown. When the input drops below 100, the main screen is shown again.
There is a ~Demo group with everything except the analog input variable which is in the Input Output Port Manager group.
- TwoScreens.zip
- (690.28 KiB) Downloaded 18 times
- Griffon
Hi, Thanks for the response, please let me clarify.
I was talking about one 780 display outputting via its digital output into another 780 display via its digital (or analog) input.
The reason we cannot communicate via other means is because the can ports are already occupied.
I just want to be able to switch an output based on a setpoint of a variable on J1939 of display one.
On display two I want to switch a binary output based on the digital input state.
I don't like state machines very much and would rather achieve this using code.
Many thanks,
Rich
Many thanks,
Rich
Hello Griffon,
Ok, so the config I'm sending this morning responds to a digital input. I used a script, just for you ;-)
Since the initial config sets a digital output already, you shouldn't need to do anything to it.
If you look at the initial config, I did not use a state machine. I used an activity program. It is different from the PowerVision state machine. Since you are a coder, you have seen or even used flow charts. Activity programs are very similar to flow charts. Much simpler than using state machines, just as efficient, processing wise, as scripts.
- TwoScreens 2.zip
- (688.85 KiB) Downloaded 24 times
