Hello everyone,
hope you can help me.
I have the PV750 an the PowerVision Configuration Studio 2.3.11157.
I need same lists:
* Alarmlist - segment to show the active alarms with option to acknowledge and defined colours.
* Measuring point list to show all the Measuring points with value and ranges.
Have it, somebody?
Or can give me a tip?
Thanks and regards,
Patrick
Ask for Alarm and measuring point list
- Kuttruff
Re: Ask for Alarm and measuring point list
Hello Patrick,
If you open a Murphy Standard Configuration with the PowerVision Configuration Studio and go to the Database section you will find a list of J1939 Parameters already defined.
In the Environment Setup section you will find some of those parameters have been mapped to different devices under each CANPort. The parameters that have been mapped will be available to be displayed.
In the Page Designer Section you will find rotary gauges, text gauges, and bar gauges linked the parameters mapped in the Environment Setup section. Notice that the gauges have their own ranges that might be different from the parameter ranges defined in the Database section.
In the Databse section you will also find the DTC list. This list defines text messages for different SPN/FMI combinations.
The Murphy Standard configurations already have a state machine that will show DM1 alarms when they are received. A message will pop up with the border matching the lamp status color, the SPN, the FMI, and a text description if it has been defined in the DTC list.
Let us know if you have more questions.
