- New Raw CAN Logging System. This feature allows you to record a limited amount of Raw CAN traffic for use in debugging and diagnostics.
- Find All References” in Images allows you to see where images are used in a configuration.
- Ability to Scroll Text in a Text Widget
- Support for clipping a container widget.
- New Switch Statement in Activities Programming
- Ability to Center Align Gauges in Page Designer
- Ability to Position State and Activity Objects with the keyboard.
- Ability to Scale Free Form Variables using Resolution and Offset.
- New Graph Widget (Also in 2.7 Patch 2) and Supporting Activity Shape.
- Performance Improvements and Optimizations to Embedded Runtime.
- Configurable Timers. Timers can be adjusted on the fly by changing the timer's associated variable.
- New Networking Features
- Support for Custom Lists (Also in 2.7 Patch 2)
- Ability to read a DM String in Scripting.
- The new MPC10 controller is supported. This is a Beta version of the hardware definition. A standard configuration is included.
- The Diagnostic Messages application supports a new way to implement internal alarms, Alerts, and associate the alarms with bypass timers for lockout and bubble delay.
- TSC1 Control Application is included on all monochrome displays to help with more reliable and consistent TSC1 messaging.
- PV300, PV350 and PV380 Digital outputs are now handled by the Input Output Port Manager.
Example configurations using new or updated features are here
